- Replies 14
- Views 10.1k
john greenman 3 posts
CSM 3 posts
flagmanruss 2 posts
AH64ID 2 posts
There may be existing threads on this subject, but when I had my engine rebuilt, I was unfortunately convinced to go with Marine pistons. Now, more than a year later, I am still not happy with the way the engine runs (I have been through a lot sorting out mistakes that were made, too numerous to go into). In any case, the rougher idle, lower fuel economy and higher egt are all negatives. As I understand it, marine pistons require marine injectors. My question is, short of pulling the engine, yanking the pistons and going back to stock, are there any options to using a more efficient and smoother running injector? Thank you
