Eletrical? issues. No radio/dome lights?
- Replies 4
- Views 1.7k
Mopar1973Man 1 post
98whitelightnin 1 post
RebelsPayback 1 post
Haggar 1 post
Kinda of a long story.Changed my fuel filters yesterday. I noticed when I was trying to "prime" the canister that my fuel pump wasn't running.... At all. Finally got the truck started.Prior to changing the filters yesterday, it took about 7 seconds to start the truck. You just HAD to wait that long or it WOULD NOT start. The pump would run for a second, then it would start right up. NOW it'll start immeadiatly. Even after sitting all night in the cool air it starts in about 2 seconds.Last night I installed 1 new rear view mirror (from mickey mouse to towing). Installed fine, tried to see if the power part worked. It worked for about 4 seconds then quit. Along with my radio and dome lights. No fuses have blown that I have checked so far.My "wait to start" light doesn't show up on the dash anymore (at all).I don't think my FASS 95 is working, if it is I don't hear it like I used to.My Scanguage, worked fine prior to adding the rear view mirror, now doesn't work at all...One negative battery cable was super loose, I fixed that and it didn't help anything.Truck runs just fine. My fuel pressure is steady too.HELP!
