- Replies 8
- Views 1.9k
Fishcarver 3 posts
Mopar1973Man 1 post
dorkweed 1 post
Rogan 1 post
I have been running without a boost elbow for some time and I installed the adjustable elbow today and there is no increase in boost pressure, 27-28 lbs and I am still getting over boost code. Also, if I get into it hard, as soon as I let off there is a poping noise, like a backfire in the area of the turbo. The poping noise just started last week and has only done it about 5 times and is intermittant.When I installed the boost elbow, I turned the screw down all the way, then back it out about 1-2 turns, still get the code and same boost numbers. Then cranked the screw down all the way, same results.Any ideas?
