- Replies 12
- Views 3.8k
Rogan 7 posts
Mopar1973Man 1 post
MnTom 1 post
ISX 1 post
Back story:I'm looking at this 97 3500 4x4. It's got a few issues I'm concerned about; a couple being drivetrain-related.The truck was apparently originally a 5 speed truck, and somewhere down the line, was converted to auto. when the current owner got the truck, the trans went out shortly after that. He had it rebuilt with:(parts I know)Suncoast 3-disc TCperformance VBperformance front pumpnew servosnew TV cable(parts I don't know about)"red" clutchesSolid kevlar bandsSaid he's got like $3k in the trans rebuild, and another $1k is having the place in Wesminster, MD do some rewiring, connect vacuum lines, etc., that the owner before-hand did not do properly. The issue I have concern with is that when it's first started, and placed into gear, it takes about 10 sec or so to fully engage into gear. From that point on, it's fine. It shifts solid, feels good. I'm just concerned with this initial 'delay'. Another note to add is that the "computer" had to be re-pinned or something, for the trans to work properly. I dunno..Secondly, is the tach gauge. It works when it wants to. no other lights come on when it decides to stop working, which is most of the time. when you start it, it'll hop up and work.. after about 5 seconds, it's done and lays down.. :think:AC: The compressor cycles on/off about every 10-12 sec.. but doesn't blow cold air.Guidance? Thanks.
