Questions For Electronics Experts?
- Replies 9
- Views 2.3k
Mopar1973Man 4 posts
JAG1 3 posts
Rogan 2 posts
Would there be any advantage to running a separate heavy ground cable from the PCM to the negative battery post? Would it help/ possibly save the PCM in the event of any future electronic abnormalities?Second; How about an external voltage regulator using a mechanical type regulator. I say mechanical type because if it starts acting up all you need do usually, is emery cloth the contact points. It is also has a feature of being able to adjust the voltage simply by adjusting the spring screw.Third, is it possible that the ECM Could avoid future damage if it did not have to run the lift pump and/or the AD Raptor relay? Asking because I would use an oil pressure switch that would kick in the AD Raptor pump without the relay.I thank everyone for any thoughts. Maybe going the wrong path, who knows?...... just need input from the experts.
