- Replies 19
- Views 2.8k
Elknih 9 posts
Mopar1973Man 4 posts
diesel4life 2 posts
ballbearingsandstickshift 2 posts
ok so I've been having these not starting when hot issues...as I've posted recently...Mike says put in gauge.... I get the electric installed with my triple pillar pod setup (glowshift)I'm anal and hate the way the wiring is coming out but still I push.Going to do the snubber from Geno's, pull off the banjo (filter up canister setup on mine)...I screw in the snubber, then tread the sender (tef. taped)... wire and ground.Gauges all come up (no other probes hooked yet) bump starter to bring up LP....it cycles (no pressure...nothing)try more,,,, still truck wont start either (several tries) nothing. I didnt bleed anything yet (the darkness came too fast) I did pop the filter drain and it was flowing. did I not install sender right? I'm thinking I have air in sender, but truck should fire. I did a draw straw and ran out of fuel before, never this on a priming tho. I cant see a complete how to to prine this setup anywhere.... lots of words or discussion on it, but I'm a see and learn guy (what did we do before YouTube).
