Coolant Temp sensor with factory gauge
- Replies 20
- Views 16k
Rogan 10 posts
ISX 5 posts
98whitelightnin 2 posts
mr.mindless 1 post
My truck's manufacture date is 1/97. I can't tell if it's a 1-terminal or 2-terminal connector without pulling it out or whatever. I need to replace mine (gauge lays on coldest point, SG2 says -40*F..)
Genos has a 1-wire (gray) for $55, and a 2-wire (black) for $45. Judging by the pictures, they're both the same big threads.
'89-'97
'98
RockAuto has a 1-wire (gray) for $47, and a 2-wire (black) for $28. Judging by the pictures:
the gray one is big-threaded with teflon type sealant.
http://www.rockauto.com/getimage/getimage.php?imagekey=40546&imageurl=http%3A//www.rockauto.com/info/SMP/TS382_PRIMARY.jpg
The 2-wire is smaller threads and o-ring sealer..
http://www.rockauto.com/getimage/getimage.php?imagekey=320376&imageurl=http%3A//www.rockauto.com/info/SMP/TS420_PRIMARY.jpg
I don't know which I need to buy.. I "ASSuME" it's the gray one?
