- Replies 6
- Views 2.3k
ISX 1 post
CSM 1 post
99mystic 1 post
ballbearingsandstickshift 1 post
Ok i have my 02 that was crashed and an 01. Both are H.O. 6pds. The 02 is 2wd and other is 4x4. I want to put the 02 in the 01. Has way less miles and is just in better shape. Will i have to swap computers? I want to take the gauge cluster from the 02 to have the miles match the engine. Should i have an issue or will this be an easy swap? The other thing is the 01 has a 15k old VP vs the 02 having a 80k or so old VP. Are the pumps the same with the two years? I would like to take the newer pump during the swap.Thanks
