98.5 OEM Fuel Filter
- Replies 6
- Views 2.1k
diesel4life 2 posts
Mopar1973Man 1 post
98whitelightnin 1 post
vineyardmh 1 post
I am running stock fuel line and filter with a Fass ddrp2. I have had no problem whatsoever. I have read about replacing the banjo bolt fittings with larger less fuel restrictive fittings. I'm thinking I could change the banjo bolt at the vp44 to the enlarged "DRILLED" banjo bolt and run 1/2" fuel hose to the OEM Filter.I guess my question is, "Is the OEM Filter housing drillable to handle a 1/2" hose fitting". I need some advice from members that have been there done that.Thank you, Kerley
