Firewood
Well since the weather has been mild I've been busy doing catch up on the firewood here so I'm ready for old man winter to strike.So here is a collection of pictures...So here is the 1996 Dodge 1500 getting in on the action of hauling firewood. (MoparMom is hiding!)post-2-138698193449_thumb.jpgMoparMom helping out stacking wood.post-2-13869819346_thumb.jpgThen I had to have my pic taken too...post-2-13869819347_thumb.jpgAnd then the group shot..post-2-138698193482_thumb.jpg
  • Replies 26
  • Views 6.2k
Lol, yeah I keep about a cord in my mud room. It was cut up today. Sent from my SPH-L710 using Tapatalk 2
Same here, its only about 3 feet from the stove.
Burning fresh cut wood is not very efficient or healthy for your chimney!!!!:smart:
Its freshly cut, but been dead for years. [ATTACH]4757[/ATTACH] Sent from my SPH-L710 using Tapatalk 2
I hear you, but you may be surprised how "wet" standing dead trees can be. The stuff you pictured is probably fine though, because of the small diameter. Remember Mikes, posts about the standing dead trees that were burned??????? He said the wood was getting "punky".................that's from moisture in the dead tree "rotting" the wood. For best efficiency and minimal creosote buildup in your chimney, firewood "ideally" should be 18-20% moisture. If your wood sizzles when you put in on hot coals and it takes a while for your wood to catch fire or you see water bubbling out of your wood, it's probably too wet. Firewood should make a sound similar to two baseball bats being tapped together. If you get a dull thud rather than a baseball bat type sound.......your firewood is not ideal.
It was all downed trees. But I know what you're saying :)Sent from my SPH-L710 using Tapatalk 2
Mine is too wet... Practically dripping wet. I've got to have a good bed of coals and drop the wet stuff in with a few pieces of dry wood. I've only got 4 cords of dry wood but got 6 cords of wet. What happens when you work all summer on the fires and get back too late to split and stack it all.
And what was MoparMom doing while you were galavanting around Idaho with the fire crew?????:whistle::stuned: Tending the fields???:lmao2: We've seen how you work her!!!
