- Replies 16
- Views 3.2k
AH64ID 6 posts
AGD03Dually 5 posts
flagmanruss 2 posts
dorkweed 1 post
I have pulled all injectors and had them tested. #1 & #6 had high return flow. I replaced the two with high return as well as installed a 3 micron fuel filter, it started fine the first few days ( I have driven less than two hundred miles ), until the nights started getting cooler (<50 degrees), and it started with the long cranks again (multiple 20 second cranking cycles). If I plug in the block heater it starts in 3-5 second crank cycle. After driving I can shut it off any time and it starts within 3-5 second of cranking, just not cold. Prior to all of this I have Never had to plug in the block heater. I also, do not get any codes :banghead:
