Bought DTT Assassin Mechanical Fuel Pump- No Install Instructions! Please Help!
- Replies 8
- Views 6k
Texas CTD 3 posts
Mopar1973Man 2 posts
flagmanruss 1 post
98whitelightnin 1 post
Greetings-From Steffen at DTT ...I purchased the Assassin Mechanical Fuel Pump for my '98 24 Valve-I also purchased the Vulcan Double (Filter and H20 Separator)To install along with it. My idea of how to install the Pump etcis as vague as the instructions included with the pump. Which consists of a simple line diagram with little or no descriptions of where different fittings, filters, hoses go...there are not even instructions as to where to put the pump...where the individualbolst may go. Yes-given lengths of time and trial and error I could most likely figure it out, but I have had my truck off the road (A FUll MOTH) waiting for this pump. I already replaced my Injection Pump (which was fried) and now I want to keep that from happening once again with the Assassin.I have removed the old lift pump, and the stock fuel filter setup,I know I have to drop the fuel tank and install the daw straw-but where do I go from here. Do I use the hard fuel lines?How do I run them?Has anyone installed this on their rig? Someone who could direct me to some installation instructions that merit fallowingand provide a bit of guidance? Or maybe you have some picsof when you installed your own? Or know of a thread with step by step info? These would be so helpful- I am slammed- we need to move ASAP into our new home-freezing weather here in Deer Park, WA and it is going to take out our house water pipes if I cannot get moved in soon- (We just purchased a shop/house)- I am up to my neck in this project and have nothing with which to tow our trailers- Any help would be AWESOME! I need an experienced hand to show me the way-THANKSShawn
