Im corn fussed ?? replaced the injector pump and now i have an issue with excessive oil blowby ,its seems i need to be going better then 55 for this to happen ? any suggestions were i should b investigating first, thanks .
  • Replies 9
  • Views 1.7k
Vacuum line unhooked or broken? :shrug:
I'm with Mike. It's extremely unlikely that a new Injector pump would cause blowby. Has to be a hose or line left loose or unplugged. If you truely have blowby, then the engine is tired, and a new pump with as new pressures, just made it blatently obvious that the rings are gone.
I want a video of you looking at the blowby at 55mph+!!!!:think:
:thumb1:
That would be a trick.. Unless it's REALLY, REALLY BAD..
:thumb1:
I won't go there I'm sure ISX would gladly mount his camera under the truck to show you that. :whistle:
As for blow by typically it increase with boost pressure just the way things are. But I would say it going to be the vacuum lines are off first. If that all checks out then next step would be doing a compression test to verify the cylinder health.
I won't go there I'm sure ISX would gladly mount his camera under the truck to show you that. :whistle: As for blow by typically it increase with boost pressure just the way things are. But I would say it going to be the vacuum lines are off first. If that all checks out then next step would be doing a compression test to verify the cylinder health.
i will b double checking for vacume line connections , ill need to find a diagram thow, thanks , ill keep u informed, And i'll work on a video for ya :-):lmao:
Got you covered... (Thanks ISX!)
Posted Image
Posted Image
