- Replies 25
- Views 5.6k
mr.mindless 10 posts
diesel4life 5 posts
Rogan 3 posts
War Eagle 3 posts
High miles, deleted, lots of fresh parts. The business that owned it changed direction and sold it when the rear end blew. A friend picked it up cheap a few months ago and had a shop rebuild the rearend. It was broken in properly, rechecked, and filled with synthetic goodness.352k 2007 4x2 6sp C&C with 9.5' CM flatbed. 30k on delete, head gasket, turbo, injectors (it was loosing coolant, turned out it was the EGR and that's when/why). 9/10 on paint and body.Smarty Jr, no blowby, 3.42 gears, fresh brakes, front beam axle and steering were gone through, tranny is tight and doesn't grind, South Bend twin disc & hydraulics.cruise non-op, ABS light is on, needs tires, needs E-brake refreshed, driver seat has the typical wear.
I'm real close to sending him a deposit, and I haven't even pulled the valve cover off my pile yet.
