Fuel line system OEM fuel filter to VP.
- Replies 7
- Views 1.6k
Texas CTD 3 posts
98whitelightnin 2 posts
JAG1 1 post
joecool911 1 post
Looking for the best way to re plumb between the fuel filter and the injection pump. I need to include a connection for the fuel pressure gauge and a way to bleed off air from the system following filter change. I like the needle valve concept as a way to shut down the cross connection and act as a snubber. Want to eliminate the banjo bolts. Someone must have pictures. Also sources for the parts would be appreciated.
