- Replies 5
- Views 1.9k
98whitelightnin 1 post
dripley 1 post
diesel4life 1 post
ram350002 1 post
I have the chance to pick up an AirDog 100 with the twin filter set up for CHEAP. The short story on it is the guy was having problems with his truck running so he took it in to a shop and they told him his AirDog was junk. didn't have a fuel pressure gauge so had no idea what kind of fuel pressure he had and told the shop to change it out. Well didn't cure his problem so he wound up with what he says is a Perfectly Good spare pump. I told him I would be interested in it if I could bring it home and verify it does run. So I've got it in my vice at the moment ( I do not want to go through the hassle of installing it on the truck with out knowing it runs). The question I have is this. There are 2 wires coming out of the pump. I assume the red is positive and green is ground? Also on the regulator there are 2 posts, one marked "G" and one marked "M". Does the regulator need to be grounded as well? And the "M" ImI'm guessing is supposed to be an ignition source but I should be able to put 12. Volts to it and the pump should run. Am I on the right track here? The guy who owns it kknows nothing about it so II'm kinda winging it. Thanks for any help!
- - - Updated - - -
Well I tried to wire the pump up like I described/asked up above and no dice. So looks like Im going to be dropping the pump back off to the owner tomorrow. Real bummer because my Raptor gave me a real scare the other day and I ddon't have a lot of faith in it now. So now to decide what to do, wait until it craps out on me and keep my OEM carter with me at all times so I can swap it out real quick if need be, spend big bucks on another electric jobber that has a not so great reputation lately, or take the plunge on a mechanical pump....
I hate these kind of choices!
