Just changed my fuel filter, truck has not been the same since!
- Replies 20
- Views 5.5k
jshalala 7 posts
Mopar1973Man 5 posts
dripley 4 posts
Lone Watie 1 post
Here is the deal. Saturday I flipped up the drain valve for the fuel filter canister to drain the fuel out. I unscrewed the lid for the fuel filter, pulled the old one out. Snapped the new one into place and made sure the new gasket was seated. Fuel filter canister looked clean so I installed the new filter. Pushed the drain valve back down. turned the key to on and I could hear the lift pump working to fill the filter canister back up. Repeated this two more times. Started the truck and it ran good for a couple seconds then died. I then repeated the same process with turning the key thinking it still did not have enough fuel in the filter housing. Cranked it three times and it was cranking strong but still no start. Had it cranking for maybe 15 seconds start but still no fire. Left the key turned to on for about a minute to try and get the filter housing full of fuel. I finally pulled the new filter back out and turn the key to run and the canister filled all the way up. I had to displace a little fuel to get the filter to screw back down. Bumped the starter twice, then cranked it and it fired up and started running smooth again. Two problems since then. 1) my drain valve is leaking pretty steady at idle. Figure the o rings are bad so I just purchased an entire new drain valve and o rings from fleetguard and should be receiving that in a couple days. So I should have that problem solved. 2) When cruising at a steady speed it seems like the truck surges very slightly every once in a while. Passengers cannot notice it but I can. I dont remember it doing this before I changed the filter. Could there be air in the lines and that cause a surging? Did I fry my vp44 by cranking it without fuel? I already attempted to reset the APPS and it didnt solve the problem. Truck starts and runs great now with plenty of power, I just can notice the slight surge while maintaining a steady speed. Any thoughts? Unfortunately I have no way to check fuel pressure right now :banghead:
