- Replies 12
- Views 3.5k
Mopar1973Man 3 posts
diesel4life 3 posts
Wild and Free 2 posts
hex0rz 2 posts
MAN! So today I got the trailer hooked up and took it out on the road! :ahhh:I can't back it up to save my life. :doh:I did better backing at our destination, but now I done a number on the grass...I planned the route taken to avoid many things, one of them being the bridges... Except when I got about 2/3, 3/4 the through the trip, it started POURING!It was quit the first trailering experience...My trailer is 8'8" wide. The tow mirrors don't get me planed out with the trailer. I can still see behind me, but not straight back...You can definitely tell it IS BACK THERE!I have learned too much in trip already...I estimate 305 horsies with my mods. Making a grade, it started making alot of heat and peaked at 25 psi, just under 1000 on the pyro. Trans temp. was good at 135-140 on grade. I think I need to step up to a larger turbo, one above stock... Maybe I can chip it instead and that would help?Coming down, hit the trailer brakes on the controller a little instead of the fat pedal.Backing in at our destination was a little rough. I was trying to negotiate the turn and I was watching the trailer approach the back of the cab. The bottom of the front ended up rubbing on the bed rail. Did not see it as the back seat blocked my view. I thought, "OH CRAP!" :mad:Backed out of it and took a look at the damage. Got a slight dent in the rail and a scuff on the trailer. Think mr. clean magic eraser should fix the scuff. A slide hammer on the bed rail should help... :cry:My biggest issue at the moment is the trans. temp. I dunno how long it went on for, but I did not look until after assessing the damage. It got up to 220, I think. I thought I read it should never go over 200. I did not think for the slightest moment it would get so hot backing it in. I'm definitely going to add an aux cooler! I took a look at the trans. fluid. Checked out, did not smell burnt.I spent probably 10-15 min. cumulatively to get the temps. down and stay below 200. One small negotiation at a time...I also cannot figure out a noise that occurs as well. I'm thinking its possibly some slop in the hitch head jaw and the pin, or the little bit of slop the sliding hitch has on the hitch itself. Just a little front and back movement. I can't figure it out. I start moving, and just maybe 1-2 seconds after starting to move it will make the noise. Its not consistently every time either. It also was happening some times at stopping as well.Is that a normal occurance for the superglide?Well, I got about 115 miles or so on a 1/4 tank with this beast!Got a little grayer, too.... :ahhh:I'm here still!
