if you warp/bend/mame a connector tube when installing injectors is it obvious?
- Replies 16
- Views 15.5k
Mopar1973Man 3 posts
JOHNFAK 3 posts
farming24v 3 posts
Cordell walker 2 posts
hey all...I had a stuck injector last weekend so I replaced them with some even bigger ones (220hp vs 175) bc they were the only ones I could find on the saturday of memorial day weekend. Is it obvious with how the truck idles if there's an issue with the connector tubes? I dont know if there is, but the truck idles meaner with the new injectors anyways so a comparison to before isnt fair. The truck appears to be running fine, but it is way smokier than before. I know that could be the injectors just being bigger and smokier. We couldnt find any connector tubes over the holiday weekend so we reused the old ones that have been tightened on multiple times, and clearly over the 28ft lbs normal torque.
