Dodge Gauge pod...
So, I didn't want to spend any more money than I needed too, but I did need to run a boost gauge between the primary and secondary, to see what my primary is lighting at. I already had a boost gauge, pyro, and fuel pressure. I still had my autometer mechanical 0-60 boost gauge, so I didn't have to spend any more money on that, and I still had the old A pillar 2 gauge mount.
After some quick cutting and fitting, here's what it turned out to be-notice anything different?
Posted Image
:gages:
My own Dodge 4 gauge pillar pod!
Posted Image
  • Replies 25
  • Views 8.8k
:think:Ummmmm.....let's just sat between an exacto knife and my wifes abilities with a needle and thread it will....
:think:
:lmao2:Thats pretty good. I have been thinking of adding another gauge to mine and dont want one on the steering column. Just so happens I have and old 2 pod mount myself.:think: hmmmmmmm.
- - - Updated - - -
I have seen a 3 gauge pod that would mount on the dash pad. I just dont think I can bring my self to cut a whole in my new dash pad, but you never know.
I've seen those and actually had one in this truck before I owned it. We just unbolted the dash up front and ran the wires between the dash and the windshield. I don't want to go with that yet just because I didn't want two empty holes in a gauge pod...and I didn't want to spend the money.
I would rather have them there than on the a pillar. Just want it clean and no exposed wires or holes in the dash pad. Still thinking of what I am going to do.
That looks really good! How many times have you bumped your head on it? :lmao:
None Yet! *knocking on wood* I did get a surprise today in the mail...I completely forgot I ordered a drive pressure gauge....:doh: Sooooooo, now i need to find one more spot somewhere for another gauge....I think my apillar's pretty full at this point-gonna have to think about this one for a bit...:think: I did find out though, that the visor will go down, with a little "gentle persuasion" on the bendy end...
Thank the lord for the bendy end. 5 gauge pod:think: hhhhhmmmmmm!!
I did find that picture last night, at some point...from here, it looks like its just the gauge, right? not a full pod surrounding it?
That's right. I took some closeup pictures of it an hour ago and need to have my son up load them. Hopefully they will be up tomorrow.
Ok, thanks! I'll have to look into it, and see if what I'm thinking will fit there-I'm planning on wrapping the gauge in the last port on my cut up 2 gauge pod, and I don't know if that's going to fit between the window and the bottom gauge...
That JGS particulate filter is pretty expensive ...., how often do you need to clean it ...., and are there other options that you know of ?
It is, but after a lot of research, it seems to be the best one out there, to filter out both the soot and the moisture. Everything I've read is that with all the other filters, it seems to be a bit more of a pain to keep them clean, and they don't seem to catch everything. With the JGS one, I haven't heard of anyone running into issues keeping their lines clean. I don't know how often it needs to be cleaned out, bt the come with a petcock on the bottom of the filter, and an air fitting on the top, so you can hook up a air chuck to the top of the filter, and blow all the particulate matter out the bottom.
- - - Updated - - -
[ATTACH=CONFIG]5736[/ATTACH][ATTACH=CONFIG]5737[/ATTACH] Here is the closeup of the boost gauge at the bottom of a 3 gauge pod.
Thanks for the bigger pics! I think I will mount to the bottom of the pod, but with the setup I've got, I'm thinking I'm going to go on the other side, as it will fit a bit better...I might do some mockup tonight, and see what I"ve got going on...
- - - Updated - - -
I just pulled it out of the truck tonight, to modify it some more, as I've decided to mount my 5th gauge on the pod. I marked the pod in the truck, so I know it fits, and then pulled it all out to mold them together.
As I marked it, and before I cut the hole out for the wires to go through...
Posted Image
Hole cut out with a dremel, and then smoothed out with the sander wheel on the dremel.
Posted Image
This is the second pod of the 2 gauge pod, after I've cut it to fit the area...it doesn't like up exactly right, but with how I'm planning on mounting it, I'm not too worried...
Posted Image
1st step, I used some 2 part 1 minute epoxy, and some fiberglass. I cut out strips of fiberglass, laid the epoxy on the plastic, and then placed the fiberglass down on the pod. If I had to do it again, I think I'd get some slower setting epoxy, as it dried up pretty quick, and if I didn't get all of it on the pod immediately, I wasted a lot of it. It's solid though, there's absolutely no give on the pod...
Posted Image
2nd step, I got a small tube of glazing spot putty, for metal, fiberglass, etc, and then coated the pod over the fiberglass. Once it dries out, I'll sand it down, and touch up if needed. Once that's done, I'll paint it over, and reinstall.
Posted Image
A few more pics as it stands right now....note to self...either use actual fiberglassing epoxy or switch to a 5 minute epoxy...the 5 minute epoxy allowed me more time to lay the fiberglass and to smooth it out before hardening...
Top pod redonePosted Image
Overall pod....Posted Image
Bottom one mostly sanded....Posted Image
Inside of pod. I ground it out so the hole matched up with the outline of the pod itself...
Posted Image
LMAO! I like it! I'm stealing that one!:lmao::thumbup2:
Just another update, all I need is the paint to dry, and I can put it back in!
Sprayed it down with a rattle can herculiner, so it would flex better, and hold a little bit more texture-that's the idea, anyway! I'm not spraying the inside, I could care less how that looks, since no one's ever going to see it but me!
Posted Image
Posted Image
The bottom pod sprayed...not the best picture, but it melded together fairly well, considering I've never fiberglassed a thing before in my life!
Posted Image
Top one...Yes, it looks really funny from this angle, but that's the same angle I had it at before I actually fiberglassed it to the pod. From inside the truck, the angle's really not that bad...same angle as the first pic I took of it, just a little less material now.
Posted Image
Hoping the paint will dry by this evening enough to put it all back together...the wife really needs the Jeep back; been driving it for the past two days now with my gauges and wires hanging all over the truck right now!
Looks like you're going to have your hands full putting all the wires and plumbing in. Have a cold one and dive in.
Wasn't too bad. Since the three gauges were isspro ev2's they had a wiring harness that I tied into all three gauges, so there were only a few loose ones. The isspro drive pressure gauge isn't wired yet because I still need to get it setup first, but it only took about 15 minutes or so.
The dp gauge is a bit off to the side, but from my normal vantage point driving I can still see it. And really I'm not too worried about it because once I get everything tuned, its not a constant monitor gauge either.
Posted Image
