Bought fuel last night and noticed the label. What could be the other? [ATTACH]5785[/ATTACH]2003 Ram Cummins NV5600 with gauges and a Smarty! Not much more.Sent from my iPhone using Tapatalk
  • Replies 7
  • Views 2.9k
Biodiesel is renewable so maybe they just wanted to make you aware of that :shrug:
But unlike ethanol Biodiesel is actually good for our rigs and has benefits like added lubricity to fuel. At the last mine I worked at they did a year long experiment and found that 10% bio was the best bang for the buck all around before noticing a loss of power and fuel economy, it was easy to track when they burned 35-40K gallons every 24 hours.
If you run a lot of bio diesel, doesn't that make it necessary to have two fuel filters? One in front of the lift pump and with the factory one? I heard of a VP rebuilder who said one of the biggest problems is the use of biodiesel without enough filtration. Not sure how much experience this guy actually had, but I remember him saying that.
Biodiesel is typically a dirty fuel when home produced. Commercial fuel production and biodiesel is fairly clean but still has it winter problems of gelling and separating.
Not quality bio. Bio WILL clean your fuel system and you do run the risk of plugging your filter not because it is a dirty fuel but because it will clean things so well.
I ran B20 in the winter once and it was awesome. It started like it was summer and I never had any issues at all. The high cetane is the trick and being biodiesel you have all the lube in the world. You might lose some mpg but it might actually be better. Antigel stuff detracts lube so even if you do add 2 stroke, it still might not be enough. Remember the HFRR was probably done with summer fuel..even though they did 200:1, it would be better if they did 128 with winter fuel and then with summer. B20 kinda eliminates any and all lube issues.
