Thoughts on bolt in transmission pan adapter
- Replies 26
- Views 5k
Wild and Free 10 posts
joecool911 5 posts
dennhop 3 posts
Yankneck696 3 posts
I see that Geno's carries a bolt in after drilling transmission pan adapter to install a temperature sender. Seems you drill a hole in the tin pan and install the compression fitting. Does this sounds like a viable option to buying an after market aluminum pan for a couple three hundred bucks? My transmission is due for service and seems like a good time to add the temp gauge.
