- Replies 11
- Views 2.3k
CUMMINSDIESELPWR 6 posts
Mopar1973Man 2 posts
ISX 1 post
dripley 1 post
so drivin down i25 @75mph with ac blowin cold outside temp 99F. temp gauge showed a bit higher than ive ever seen about 210. no problems, coolant is good never had a problem with overheating or over cooling till now. i wasnt hauling anything either.
Now the issue i think is the tstat is stuck open allowing over cooling. barely will hit 170 in 99f heat with ac runnin doing 65.
the fan is working fine, blowing strong but not locked.
so i am gonna order a new 195f tstat and bolts then swap this week.
thoughts?
