Posted July 18, 201312 yr Ok any thoughts on a good flowing and good filtering// air filter for my 2012 6.7?
July 19, 201312 yr One word...STOCKThe stock filter will outperform anything you put in there under 450-500rwhp, and non-stock filters have the potential to trip a CEL. The revied 5.9 filter and 6.7 filter are nearly identical in flow/size, and I am pushing a little over 100rwhp over stock and moving a lot more air with a cam and better turbo and the stock filter minder doesn't budge and my UOA shows lower silicon than other filters I have tried (before the OEM 4" filter came out). It's just not worth a swap.
July 20, 201312 yr Author Ok thanks alot. I will stay stock. Its only got 2000 k on it anyways..haha Any advice on any aftermarket stuff that is warranty safe to start to freshen it up for mpg and stuff? One word... STOCK The stock filter will outperform anything you put in there under 450-500rwhp, and non-stock filters have the potential to trip a CEL. The revied 5.9 filter and 6.7 filter are nearly identical in flow/size, and I am pushing a little over 100rwhp over stock and moving a lot more air with a cam and better turbo and the stock filter minder doesn't budge and my UOA shows lower silicon than other filters I have tried (before the OEM 4" filter came out). It's just not worth a swap.
July 20, 201312 yr Ok thanks alot. I will stay stock. Its only got 2000 k on it anyways..haha Any advice on any aftermarket stuff that is warranty safe to start to freshen it up for mpg and stuff? Stock and drive it.. Nothing will do what you want without mods to the EPA section of the truck.
July 20, 201312 yr Author Ok....sad but if I have no choice but that. :wow: Stock and drive it.. Nothing will do what you want without mods to the EPA section of the truck.
July 21, 201312 yr It's really not worth it. Anything will void the warranty, and the tuners that add power with the DPF installed run the risk of damaging the DPF from additional fuel, and any economy increase from better timing/etc comes at additional regens since optimal economy isn't as EPA friendly.
July 22, 201312 yr Author Ok thanks again. I will hold tight till warranty is up. 5 yrs of 160k. My 10 year old 5.9 only has 180k on it still so I guess 5 years lol. After that I will look at deletes etc maybe. Seems like a 6.7 is a big powerful engine waiting to give more. haha It's really not worth it. Anything will void the warranty, and the tuners that add power with the DPF installed run the risk of damaging the DPF from additional fuel, and any economy increase from better timing/etc comes at additional regens since optimal economy isn't as EPA friendly.
July 24, 201311 yr I agree with John, you want to stay with a good paper element!! I was having trouble with mine and my filter minder would always max out (Indicating plugged filter!) so I went with a very large element. It is so large to get it in there I had to move that battery over to the drivers side. If you want I could search for a pic of it to put up here.My theory on filters is: The larger in paper the better! Better air flow and also better filtering ability. I too have great OA numbers. All the research I did online showed that all the 'after market high flow' filters let much more dirt into the engine. All of them!!! Now a lot of people claim they have run some of them a lot of miles but the way I look at it is, the cleaner I can keep my engine then the longer it has to last!!
October 22, 201311 yr Author Thanks Millco! I will stay with paper and the factory OEM box then. I guess a Mopar paper filter is the only one I can use basically anyways.
October 23, 201311 yr If your staying with the stock filter, from what I've been reading, Mopar is as good as most others, but your paying more for the Mopar name. They order their filters from filter companies who can give them constant product availability and cheap prices, then stick the Mopar name on it. The standard pleated paper filter or the over size paper filter from any decent company should work fine.
October 23, 201311 yr I would buy after market. Just open the box & look at the filter before purchase.
October 23, 201311 yr I would buy after market. Just open the box & look at the filter before purchase. What aftermarket filter provides the same or increased airflow and filtration? While not setting a CEL on a 6.7?
October 23, 201311 yr So, if a guy puts a BHAF on a 6.7L it will set a CEL? I did not know this....... What is the code (So we can figure a way around it!)I really need to find and post a pic of my VB-BHAF!!!
October 23, 201311 yr Adding a larger filter to a stock 6.7 has the very real potential to set a CEL for the mass airflow sensor out of range, or something to that effect. The increased flow isn't appreciated by the computer.But on a stock truck why do you need an aftermarket filter when the OEM one is capable of more than 100hp over stock?
October 23, 201311 yr Sorry if I was unclear. I meant a stock replacement, non-mopar branded, pleated paper element in the OEM airbox. There are lots of filter companies. Examples: Fleetguard AF27684 Wix 49946, Wix 46930
October 23, 201311 yr Owner Wow. I've learn more again. I didn't know they had mass-air flow sensors on the 6.7L Cummins. So adding a larger filter will set a mass-air flow sensor code? Interesting.
October 24, 201311 yr Author Thanks again for the input. It seems the 6.7 is not as friendly as my 5.9L. So.....if I was to do something to my truck for performance/mpg, start with a tranny software upgrade??
October 24, 201311 yr Frankly, the latest Generation of CTDs have benefited immensely from the experiences of all those who went before. The earliest were not intercooled, remember. This factory intake is now so good that there's really nothing to be gained by messing with it. That's a good thing. Just put a high quality paper element in there. I wonder if it'll throw a code if a K&N is put in there? Wouldn't that be funny?
October 25, 201311 yr Author Thanks for the history lesson...haha I owned a 93,03 and now a 12 CTD. I do love them. The truck has a OEM paper filter already (obviously) so since I don't know of a better filter I will just leave it.
