Correct Clutch Pedal Adjustment
- Replies 5
- Views 9k
Mopar1973Man 1 post
tonyjsan 1 post
bjytech 1 post
Ilikeoldfords 1 post
I recently had installed a South Bend DD clutch (sdd3250) and replaced the hydraulics with south bend as well. My question is what is the correct "Clutch Pedal adjustment", should this be set such that the clutch behaves a certain way (aside from engage/disengage ok). or just set pedal height to one's desired comfort level or maybe it's none of the above and I missed something lol. Right now the clutch pedal is about 1" above brake pedal.If you have a double disk clutch, would you mind sharing with me how different the truck drove after the install. I went from a stock clutch with worn out south bend hydraulics to double disk.Thanks in advance,Tony
