How do I Turn off the A/C??
- Replies 8
- Views 2.6k
AH64ID 3 posts
pepsi71ocean 2 posts
Ilikeoldfords 1 post
twentyohtwo 1 post
Hello, I am new to the site and new to the Dodge world. I recently bought a used '99 Ram 3500 and it is in pretty good condition. As the weather here in Northern Utah is getting cooler, the need for AC is decreasing. On the air direction selector control (I have no idea what the legal name is for the control) the majority of the vent positions turn the AC system on. The selections are OFF, AC Max w/upper vents, Normal upper vent, Lower and Upper vent, lower vent, Lower vent w/Defrost, Defrost only. (I think I am forgetting one?) Any way, this is the first vehicle that I have owned that has not had a AC power button, so the AC system in this truck, and verified in my the owner's manual, runs in all modes except upper vent only and lower vents only. In the winter, why would I want the AC to be running if I am trying to heat the cab? Would the extreme cold outside adversely affect the AC system, causing it to freeze up and damage itself?I assume that I could pull a fuse, maybe reroute the serpentine belt--or maybe none of this is a big deal and I should just leave it. The OCD in me would like to just shut it off when I don't want to use it. Thanks for your help.
