- Replies 9
- Views 2k
Andrew1346 3 posts
mopartechnician 2 posts
cajflynn 1 post
JOHNFAK 1 post
I have an 01" qcsb. Since almost a year ago, every time I pull my camper down the interstate, I will loose first gear. Now, I do tow in overdrive, camper only weighs 5k. I am thinking when the governor sensor blows, is when it downshifts into third. I have changed the sensor three times myself, along with the governor transducer. After the third time I dropped it off at the dealer, didn't have the time or patience to look at it again. They changed the solenoid under warranty twice, the second time they changed the overdrive solenoid I believe? Which included a harness that plugs into the governor solenoid that keeps going. So basically, the governor solenoid has been changed, a lot. The transducer has been changed. The harness has been changed. What else is left? Oh, and to add, the first time it did this, I wasn't towing, I was on the interstate for a three hour trip.
