Alignment (front-end)
- Replies 12
- Views 6.2k
Rogan 4 posts
dripley 2 posts
rancherman 2 posts
dobienut 1 post
I got the truck inspected last week. On Sunday, I replaced the track bar, due to a completely worn out TRE.This morning, I had it aligned. I requested that they max out the caster (4.0+). The tech said he would, and he tried. But, there's an issue with worn out bushings and eccentric bolts in the LCAs. The max he could get was ~ +3.0. I'll attach a pic of the print-out, shortly, as I forgot it in the truck.So I see where various places offer bushings, but I cannot find where to get replacement eccentric bolts, other than the dealer. Anyone have any suggestions as to how best to go about this, and options on the bolts? Should I press out/replace the bushings, or replace the LCA assemblies, all-together? Cost is a factor, obviously, but at the same time, "time is money"..Thanks.
