$85 Dollar Experiment
- Replies 13
- Views 4.3k
War Eagle 6 posts
AH64ID 2 posts
flagmanruss 1 post
diesel4life 1 post
I am still hunting around for ways to increase mpgs. I have unloaded my camper for the season and have my Leer canopy back on the truck.So I have decided to conduct another experiment by installing vortex generators on the canopy to see if I can gain any benefit.I use vortex generators on my plane to give me a lower stall speed and still maintain control of the airplane and keep it flying at lower speeds.The vortex generators create a turbulent air stream aft of the generators and that keeps the air attached to the wing at higher angles of attack (steeper pitch of the wing).The theory is that vortex generators on a truck canopy will create spiraling turbulent air that will stay attached to the surface of the canopy and bend around the end and sides to break up the vacuum drag that the truck creates as it travels down the road. This vacuum pocket pulls on the back of the truck creating a drag on the truck. To overcome this drag requires more hp (fuel).Therefore, if I can reduce this drag somewhat I might be able to realize a small increase in mpgs. So I have invested about $85 to buy the vortex generators and paint them and install them on my canopy.Reports from others that have tried installing AirTabs (vortex generators) have yielded improved road handling in high winds and when large trucks pass you (eliminates the buffeting) in all cases. But when it came to seeing an increase in mpgs the results were a mixed bag. Some saw measureable improvements while others didn't see any improvement in mpgs or the improvement was so small in wasn't really measurable.But I spent the $85 so I am going to try it out for my truck and my driving style.
