MAP Electrical connnection plug - how do you do it ?
- Replies 13
- Views 2.8k
Mopar1973Man 4 posts
mariner 4 posts
JAG1 3 posts
mopartechnician 1 post
Hi Guys,I am attempting to unplug the electrical connectionplug for the MAP sensor and I can't get the darn thing to move.I see (with the use of a mirror) two red pieces down near the brass part of the MAP sensor - on the plug body. Are these supposed to be pushed to release or pulled to release ?I cannot for the life of me figure out how it comes off (at 69 I'm getting slow and old eh!). It is a pain as there isn't a lot of room to work in to start with.While I am on the subject of electrical connectors - is the IAT the same or a different type to unlock and remove ?Sheesh, why does Dodge have to be different to everyone else re connectors? I'm not an electrician so my experience is limited with these things.Any help you could send my way (like instructions on how not to bugger up the connector) would be greatly appreciated.I am trying to sort out why I am getting a P0216 for the injection pump - which I believe is fine. I am trying to check other sensors that contribute to the injection pump operation. A dirty sensor or a failed one could cause erratic operation.Thanksmariner
