Exhaust brake woes at 0 degrees
- Replies 6
- Views 1.9k
twentyohtwo 2 posts
Mopar1973Man 1 post
ISX 1 post
Ilikeoldfords 1 post
Hey folks, This is my first winter with my Pacbrake. It had run flawlessly until ambient temps got down to around 10 degrees. Then it stopped working on my way home one night. The next morn. after I warmed the truck up for an extended period, it started working again. This cycle went on for a couple of days, then my 30 amp compressor fuse blew. I replaced the 30amp with a 20 amp. ambient temps are now around 32 and she's back to working reliably.
My compressor is located by the passenger side battery as directed in the pacbrake instructions. I routed the air intake filter to the firewall behind my Bhaf. I have not yet remote mounted the actuator piston vent that pacbrake suggested to reduce intake of moisture . ( I had to mount my brake farther down the exhaust pipe because the 4" exhaust pipe didn't allow mounting the brake on the downturn behind the turbo.)
I'm wondering if others have encountered this problem. Thanks, Bret.
