- Replies 56
- Views 8.9k
AH64ID 29 posts
hex0rz 6 posts
dorkweed 5 posts
rancherman 4 posts
After several years of wanting to go this route I finally pulled the trigger.On a normal camping trip I am between 5800-6500 on the rear axle, generally at 6000 with careful loading. Since I have 6390 lbs worth of tire I have been wanting more "buffer" room, short of a few tires there are really few options for more than 3195 lbs/tire in 17".Additionally LT tires are too soft, and tire life was dismal at best with how/where I use my truck, mainly where... lots of dirt and towing on dirt. I really don't get more than 25K useful miles out of a set of tires.This is why I started researching 19.5s a few years back. They are plenty strong, the wheels are strong and the rubber is hard enough they should last at least 60K miles.I ordered my wheels yesterday. I went with the Vision Type 81 cast aluminum, 19.5x7.5" rated at 4,500 lbs. I went with the black ones, and ordered 5. They should be here next week.For tires I will be going with Toyo M608Z in 245/70R19.5 LRG tires rated for 4,540 @ 80 psi. They are a 33" tire and roll at 624 rev/mile, 1 rev/mile different than my winter tires and should improve 5th gear towing while and empty cruise in 6th.I also have a set of Centramatic wheel balances on the way, as well as a set for the travel trailer.More to follow when they get mounted around the new year.
