Low Air Through Vents
- Replies 5
- Views 5.9k
flagmanruss 1 post
MnTom 1 post
hex0rz 1 post
Ilikeoldfords 1 post
Over the last couple of weeks I have noticed a couple of instances where the air coming out of my vents seems extremly restricted. There is a little bit of air coming through is not normal. As I move the fan speed switch I can here the blower motor speed up and slow down accordingly. The vent selection makes no difference as it will vent air where Ihave it selected. Cold or Hot, no difference there either. It didn't work all weekend, but when I got in this morning the air blew very strong?? I assume that the problem will come back. It has been cold and wet here, but nothing record breaking. Could this be a symptom of a bad blend door?
Any feedback would be much appreciated.
