- Replies 13
- Views 3.1k
dorkweed 3 posts
AH64ID 3 posts
ISX 2 posts
Ilikeoldfords 2 posts
Been wanting to do this for a long time and finally did. Basically its my truck with 245/75/16 Tires and 3.54 rear with Nv4500 Vs Nv5600.
The chart shows me shifting at 2000RPM in every gear then picking up the next gear at the same MPH that the last gear was going at 2000RPM. The numbers between show the RPM drop between gears, as in 4th to 5th on the Nv4500 drops 500RPM.
Its interesting because the 3rd to 4th gap on the Nv4500 is actually less of a jump than 2nd the 3rd, but because it is still jumping a vast RPM at a higher speed, the truck can't cope with the lower RPM and high load of high speed that it encounters, so it "feels" like a huge gap. When you compare it to the Nv5600, it definitely is a big gap. From 15-50 there is exactly 2 gears worth on the Nv4500 and exactly 3 on the Nv5600. Quite a difference. However, I am not sure but based on the chart do you guys with Nv5600's feel a slight "gap" between 5th and 6th?
