- Replies 18
- Views 15k
dripley 4 posts
Kotta390 4 posts
Ilikeoldfords 3 posts
Yankneck696 2 posts
Well I finally got my Smarty S03 and installed the SW:5 software and HOLY **** the throttle response and bottom end power jumped up significantly!!! Huge difference and still drives very easy if you are putting around. I do have a couple questions for anyone that are familiar with these programmers.
1. I noticed that there is lots of smoke if you stab the throttle before the turbo lights off. Is this part of the programming and is there a way tor reduce this some? I realize that it's wasted fuel and I don't need to smoke an intersection just to I can get up to speed quickly.
2. I figured with about 60hp increase on the top end of the power curve it would raise my boost up some. I only see a 2psi increase at WOT. I am at 23psi. Is this normal or should I see higher boost numbers? It is hard to tell if I gained 60hp on the top end, I can feel a little difference but not 60hp worth...
Edited by Kotta390
