Odd No Start, No Turning Over, No Codes....
- Replies 18
- Views 2.9k
eddielee 11 posts
TFaoro 2 posts
mopartechnician 2 posts
hex0rz 1 post
Ok so today at the park the truck didn't start.
checked codes, found no codes, checked fuses all were good.
swapped starter solenoid no change.
Took the starter out, cleaned contacts reassembled, no change.
Jumped from the battery to the solenoid and the truck cranked, fires right up...
Now the airbag $ ABS lights are on and the Speedometer nor the odometer are working, however the fuel mileage went down a bit. Will check and see if the trip miles change on the drive, I suspect not.
Truck drives fine.
Still wonder what is wrong? Any ideas?
