- Replies 6
- Views 2k
MnTom 2 posts
Mopar1973Man 1 post
Rogan 1 post
Ilikeoldfords 1 post
Yeas, so my 4WD shifter is sloppy, to say the least. Also, in 2WD, the knob is against the dash. The rod is adjusted as much as I can adjust it and still be able to select all tcase positions.
As well, sometimes when I'm in 4WD (doesn't matter if it's LO or HI) I cannot get it back to 2WD without yanking/jacking with the shift-lever for a few minutes; quite the PITA..
Is there a method or repair for these darned things?
