LOL! Now it is hard starting
- Replies 18
- Views 3.5k
flman 8 posts
Mopar1973Man 4 posts
guesswho512 4 posts
ISX 1 post
Seems that Fass feeds too much pressure and the VP44 does not like it. The pump is controlled through a relay tied into the stock pump to supply pilot voltage to the relay coil, I guess just that split second that it puts pressure to the pump is enough to screw it up. If I wait, for the pressure to drop, it will start OK. I was thinking of putting a time delay relay on the pump? http://www.primelec.com/Electronic-Components/Relays/AGASTAT-12-Volt-On-Delay-p7886012.html
