- Replies 9
- Views 2.3k
Ilikeoldfords 3 posts
milenko 2 posts
LiveOak 1 post
TFaoro 1 post
Hello All. I am relatively new to Cummins but have owned my 99 Dodge for a couple years. It has 265,000 miles on him. Everything is stock except the previous owner installed an edge EZ and I installed boost and an electronic fuel pressure gauges. When I installed the gauge last year I installed the t-fitting to avoid the hammer effect. I have a question. Here over the past couple weeks (it has been 0-20 F here) when I start up the truck in the AM the pressure will be in the single digits for about 5 seconds and then jump up to 13 or 14 psi. Do you think this is just because the diesel is cold, or is my lift pump about to quit? It is a stock LP and I plan on changing it this summer when the weather is a bit nicer. Thanks
