Pilothouse/RAM3500 build
Edited by PilotHouse2500
  • Replies 601
  • Views 237.4k
Some major surgury on the truck.  After much consideration I decided I needed to move the body forward about 1.5".  This entailed cutting off the tip front and rewelding the hinge to a new point.  Modification of the tip front frame also was done to allow for the height of the RAD. It also meant moving the cab mounts forward as well.  I also cut out a bit on the front of the frame cross member and put in a 2" angle piece to get some more room.  This SHOULD give me enough room to fit the RAD and CAC all up front where they belong.  I will have to trim the grill bars a bit as well to get things to fit.  As a side benefit, it should also center the wheel better in the fender if my math is right.
I know that sucks to have to tear down so much just to make a adjustment to fit parts. I've seen this on a few other builds I've helped with. You know that the adjustment has to be done to make things right.
picture proof I got it all stuffed in there...
Started work on the windows as I'm waiting till April to get my RAD delivered.
So the Quad doors are going to be roll down windows right? Or electric?
Power windows for all the doors and a power cowl vent as well.
51 minutes ago, JAG1 said:
The longer this takes to finish the more money I'll have saved to buy it :thumb1:
You'll be waiting a LONG time my friend....I plan on driving this till either they take my license, diesel fuel isn't available or the rapture...whichever comes first.  :tongue:
That kind of like asking me if I'll sell "The Beast"... Same answer would be given.
When those times finally get here I'll have to carry it in a dump truck and empty it on your driveway. Maybe, just maybe it might be enough by then....:pray:
It now goes up and down with POWER!
It always fascinates me when someone is able to figure out and build something like this, and it actually works. Well done 👍👍👍
 Faster second time!
preppping the front doors toward completion with adding more parts of doors to get to the final thickness.
273002692_5426242097392770_6556859230090542767_n.jpg.9c7cf16ff07107ca43f939982f3185a2.jpg272568963_5426241997392780_753671126681615616_n.jpg.445e7c93354259fd364474afdaac167a.jpg
and driver door...
Cut out the B1/B2 inside door window sill details and replaces with bit from the B3/B4 donor doors for the project (little bumpy bits visilble in previous pics).  I am especially proud of the driver side.  No warp or heat deflection!  Passenger side I got a little over zealous with the hammer and dolly in 2 spots prior to grinding the welds down.
passenger power window in
What?! No limo tint glass in that bad boy?
I've gotta ask what did it cost for glass to be cut and tempered for the windows?
And drivers side.  Oddly the second time takes 1/8 the time!  And seats placed in the cab for effect.
The glass I'm using for mock up is old glass I got from another guy for use as templates.  It's not temered it's lam glass.
Final glass WILL have a tint.  But gotta stay legal below 30% here...
got some candy Friday, but won't install for quite a while....
