47RE Dipstick Tube Venting?
- Replies 10
- Views 4.9k
Mopar1973Man 3 posts
CTcummins24V 3 posts
JOHNFAK 2 posts
mopartechnician 1 post
The other day I broke the handle off on my ATF dipstick and had to cover the fill tube with aluminum foil till a new stick comes in on Tuesday. Since covering the tube with a plastic bag then foil and zip tying so it's almost air tight and isn't going to fall off the transmission is shuttle shifting between 3rd and 3rd lock (OD off, around town driving under 50mph). Does the fill tube vent transmission pressure gas? And could this cause my shuttle shift? Or should I catch up on the lock/unlock topic?
