- Replies 55
- Views 7.5k
MnTom 13 posts
Yankneck696 9 posts
mulcher812 7 posts
volkswagon 6 posts
Has anyone run a Torque converter lockup controller like the BD TorqLoc or the done the torque converter lockup mod? If so how did you like it? when did it work best? The reason for asking is I have built my trans with a SunCoast stage 3 kit and when I'm driving around town or say under 50mph i leave the Overdrive off and everything feels good. But when I'm getting on the highway to go over 50 I turn the overdrive on and it feels like I will hit the overdrive gear at about 45 and my EGT's climb while the boost falls off. Im just trying to figure out if the torque converter I bought isn't doing what it should or if the trans is having an issue holding the gears or if maybe I need to the torque converter to lockup and hold the gears longer???
