Fuel Pressure Gauge Fluctuates
- Replies 8
- Views 5.9k
mopartechnician 2 posts
rlane547 2 posts
Yankneck696 1 post
mulcher812 1 post
Hey everyone. I have a glowshift fuel pressure gauge on my 99 and it fluctuates a little intermittently. I run a FASS 150 and I also replaced the stock filter housing with a 2 micron spin on filter and located my sending unit in the output port of the housing. Fuel pressure never drops below 15 at wot and never above 18. It seems to only fluctuate at idle. Also I removed the banjo line and replaced with 1/2 hose straight into the vp44. What can I do to stop the fluctuations and should I move the sender closer to the injection pump?
