clutches
  • Replies 4
  • Views 2.4k
Yeah they're every bit as good as South Bend, if not better from what I hear.
good clutches up too 350hp thet will start to slip after that [depends on the way you drive it ]anything after that you should look at a duel disc setup
Sold 2 clutches last week from valair. They hold up fine. often they are cheaper than SBC. I would run either in my truck.
