Power steering flush
Did a search, found no info on this. Can someone inform me as to how we do this? As I understand you remove an outlet hose and pump out old and pump in new. Any cleansers necessary? Where do indisconnect the outlet line and how to tell which is outlet?
  • Replies 8
  • Views 13.2k
2 rubber hose connections with band clamps on the back of the pump. The upper one is the return from the gear box where the most pressure and fluid will come from. Unhook at least that one or both, you might have to do a vertical slice on the hoses to get them off the pump and then cut the hoses to length, there should be enough hose. There is a hard line at the bottom of the pump but you don't need to touch that. Disconnect line(s) and put in funnel to bucket or drain pan, open cap, fill to top with ps fluid, start engine, fluid will come spitting out of gear box hose, fill reservoir as it drops, when fluid spitting out of hose is clean and fresh, turn off truck and reassemble. Refill reservoir and turn the wheel lock to lock while truck is running to purge air...front tires in the air off the ground.
What are you guys doing to plug the ports on the power steering pump when removing the hoses? Short piece of hose and a bolt in one end and a clamp set of hose clamps?
Edited by joecool911
I have one of these:
http://www.amazon.com/Mityvac-7400-Liter-Fluid-Evacuator/dp/B000JFJM14/ref=sr_1_4/187-1871939-2374555?ie=UTF8&qid=1403983667&sr=8-4&keywords=vacuum+oil+extractor
At each oil change, I just use the Mityvac to suck the power steering fluid out of the reservoir and refill. Start engine, turn steering wheel lock to lock a few times, shut engine off. Repeat sucking oil out of reservoir and refill. This keeps the oil pretty fresh over time and is VERY easy to do taking very little time.
I do the same thing with the engine coolant. I stick the suck hose in the raditator and it sucks out about 4 gallons of coolant and most of the crud on the bottom of the tank. Refill with fresh coolant. Do this every other or 3rd oil change. Its CHEAP, easy, quick, and keeps the coolant and additives fresh. I use the Shell extended life coolant ELC in my truck do I do this about every 5 to 7 years. If you use the Walmart Supertech green coolant, do this as above. Works good, lasts a long time.
