- Replies 19
- Views 2.7k
KATOOM 8 posts
Mopar1973Man 6 posts
MnTom 3 posts
TFaoro 1 post
Well I'm only hopping that what I just experienced isnt what I think it is but nonetheless.....this is what happened.
This last weekend I took the trailer up in the mountains, as I've done many times before. As usual for the north state valley area, it was stinking hot outside and I was pulling hills in 100* weather. No fun either as everything just gets too darned hot when its like that, but surprisingly this truck does amazingly well in staying within the tolerable running gear temps.
The situation I'm posting about occurred when I crested the top of one longer grade. I was at about 5500 ft in altitude, running in 3rd gear at around 2300 RPM, and the engine was on the hotter side peaking out at around 215*-220*. Thats the HOTTEST it ever gets too and only for a few minutes at longest. Having reached the top of the grade I shifted into 4th gear to let everything cool back down but strangely the throttle was non-reactive to any further increase in pedal. Weird, so I shifted back to 3rd and all throttle was normal. Then I quickly tried 4th again but still the same thing happened where it seemed the throttle didn't react to any increase in pedal. But back to 3rd again would result in complete normal throttle. So after holding 3rd gear for a couple minutes more at most I tried 4th gear a third time and this time the throttle resumed normal action. I have no idea what happened and it didn't do it again throughout the towing trip. When I got home I checked for codes but nothing. I cant tell you how much I go through to assure the VP is happy so why out of the blue I'd start to have issues, I dont know. Its 6 years old, I only shut it off when I NEED to, and I'd be surprised if I have 50,000 miles on it. I dug around the internet to see what others have experienced with dead pedal and found the same thing over and over again but of what everyone had experienced with dead pedal, the only thing I can say that would be similar was that it was hot and the engine was hot. I've driven in higher altitude enough to know that sometimes the throttle is less reactive in the thinner air but I dont remember it being like this. I almost thought the ECM was accounting somehow for the hot engine but that sounds like I'm reaching for something.
In saying all this, I do remember feeling the dead pedal running in the higher 6k-7k ft altitude about 8 years ago with the original VP on the truck but if I remember right it was a complete but momentary loss of throttle control no matter gear or anything. What I felt the other day didn't seem to be like that but then again.....maybe I'm in denial.
