- Replies 43
- Views 19.5k
Huskiemuskie 13 posts
CTcummins24V 8 posts
rancherman 6 posts
Mopar1973Man 4 posts
99 Ram 2500 4x4 auto 5.9 24V bought it with 89K on it now has 116K. The Issue I have is intermittently when it starts it has a ideal lope for about 5 to 10 seconds then ideals normally which around 740 -750 rpm... occasionally 800 rpm... The problem is/was magnified when I installed 75HP injectors... bigger lope like it had a big cam in or something... but again it would ideal normal after 5-10 seconds on it own or if gave it some pedal... it would also like to stall when putting it in reverse with the 75hp injectors sometimes... the problem is only at start up truck runs fine other then that... I put the stock injectors back in and still does it just at a smaller lope...(problem has not worsened with time) I really would like to run the 75hp injectors but the loping is like a pulling truck and the stalling is annoying... any ideas?
thx guys
