- Replies 10
- Views 2.4k
TFaoro 3 posts
Mopar1973Man 2 posts
Wild and Free 2 posts
Yankneck696 1 post
I just remembered I had a weird thing happen and can't explain nor has it occured again. While I was towing my traveel trailer this last trip I had my cruise set for 55 MPH cruising towards Emmett, ID. It was really strange it was like someone lifting and stomping the throttle in a really jerky up down random cycle. Now remember I'm a fly by wire system no vacuum motor cruise. As for error codes there is none I check while driving (Scan Gauge II). As for the APPS sensor it shows 0 while cruise is active there is no signal (Scan Gauge II). I tested my alternator noise once I got to Emmett, ID and it was a normal 0.023 to 0.027 AC volts. After being shut down for the night I've never experienced it again.
