- Replies 18
- Views 4k
JAG1 6 posts
MnTom 4 posts
Mopar1973Man 3 posts
rancherman 3 posts
Anyone know how to get the pressure washer to pick up soap to go thru it? Mine has the attachment for dropping the soap pick up tube in a bucket of soap and water but won't suck the solution in. I found the check ball and spring backwards and fixed it but still no soap going thru.
Is there some sort of different attachment besides just dropping the feed tube in a bucket of soap? Seems like it needs a pump or maybe cut the check ball spring so it's not closed off so tight. Just want the best set up as I have a log house and need it to pick up bleach, soap and wood cleaners.
I also have a box elder bug problem real bad this year and the soap kills them. Pressure washer is like a commercial sprayer if I can get the soap thru.
Thanks for any experience with this kind of thing. Mike
