- Replies 9
- Views 3k
Mopar1973Man 2 posts
Ilikeoldfords 2 posts
Nekkedbob 2 posts
joecool911 1 post
I built a mpg/high idle for my truck a month or so back and I am having a problem and hope that I can get some insight. When I turn on the high idle I get a temp reading on my Scangage 2 of 137 water temp and 31 iat temp. If and when it starts the high idle as soon as it hits 1200RPM it goes to 3 cylinder. I have a 3 cylinder switch that will make the iat read 13 degrees but it makes no difference. This has worked this way except once when the outside temp was below 32 degrees. I tried to have a dodge dealer check this and they said that I have a 12v ( manufacture date is Feb 1998 ). I know that it has been flashed for the high idle buy the PO but he didn't know that it had been working incorrectly. What the big question is if I just needs the high idle reflashed or a complete reprogramming and what I can do about dodge thinking that it has a 12v in it After 3 weeks and 5k miles I can tell that the mpg setting is working and am satisfied with it.
